Diode for anchor/masthead light
Shane anthony
Sorry if this is a simple question that’s been covered many times. Sometimes it seems I have the most trouble with the simple stuff
. Been searching this forum and google still not able to figure out what to buy off Amazon. I’m just wanting to use two wires to run the circuit, both lights have LED’s and wanted to use a double pole switch and need to know what diodes to order off amazon. Thank You in advance
Re: Diode for anchor/masthead light
Test your current LEDs. By definition, they are diodes and will only work with polarity that is correct.
I wired steaming and anchor light with the same 2 wires and reverse the polarity to toggle between them.
Now some LEDs are not polarity sensitive. I don't understand how that works, but my anchor light was like that and did not respect polarity. So I found some old electronic device that died and pulled out a diode and soldered it in the circuit.
I don't know much about diodes or how to rate them. Mine looked like this one.
https://www.amazon.com/MCIGICM-15SQ045- ... ref=sr_1_2
Shane anthony
Thanks Russ, I’m not much of a electronics wizard either. Good idea pulling that diode out of a dead device, that’s great it worked out. Was just trying to be thrifty on the amount wires incase I want to add electronic bells and whistles on top of the mast. But maybe it’s just easier to wire the anchor, masthead/deck light separately. After all it’s only one extra wire anyhow. Thanks again for the replyRuss wrote: ↑Fri Jul 12, 2024 2:01 pm Test your current LEDs. By definition, they are diodes and will only work with polarity that is correct.
I didn’t want to pull another wire through the cabin.
Just put a diode in one side of one of the fixtures. That is if the LEDs are not behaving like diodes. Plus deck fittings.
Since it is not legal to have both anchor light and steaming light it works great. All I had to do was add a DPDT switch by the switch panel.
- Hamin' X
These will work properly: Amazon DiodesShane anthony wrote: ↑Fri Jul 12, 2024 1:49 pm need to know what diodes to order off amazon. Thank You in advance
Wiring details Here
~Rich---Hamin' X---N7ZH~
Shane anthony
Thank You!Hamin' X wrote: ↑Sat Jul 13, 2024 8:42 amThese will work properly: Amazon DiodesShane anthony wrote: ↑Fri Jul 12, 2024 1:49 pm need to know what diodes to order off amazon. Thank You in advance
Wiring details Here
Shane anthony
Thank You!Russ wrote: ↑Fri Jul 12, 2024 5:36 pm I didn’t want to pull another wire through the cabin.
