That is EXCELLENT. I see the difference in the CDI furler. It uses an actual turnbuckle.Starscream wrote: ↑Mon Sep 23, 2024 12:06 pm
Here's a link to a PPT that I made trying to document the assembly of the CDI furler:
https://1drv.ms/p/s!Ag0w1ybOLvphkuk4dK1 ... Q?e=dQZ0y3
Forestay turnbuckle safetying
Re: Forestay turnbuckle safetying
- Dougiestyle
The turnbuckle is used to adjust the mast to 94 degrees as per the manual. Which is needed for proper handling. Too far forward the boat will turn away from the wind (undesirable). Too far back the boat will turn into the wind. someone on this forum used 92 degrees to balance it better, i think it was Tom Foolery. There is a good document, either in the resources on this site or its on BWY website on how to properly rig the sail on a 26X.
I use the ring dings
Dougiestyle
1998 26X , Nissan 50D, "Water Buffalo"
Shane anthony
Actually when I unhooked the forestay to mess around with the different ways to secure the turnbuckle I tightened it thinking it felt to loose before. After I took that picture I went to hook it back up, no way was i getting that pin in so I had to loosen it.Starscream wrote: ↑Mon Sep 23, 2024 12:06 pmHere's a link to a PPT that I made trying to document the assembly of the CDI furler:Shane anthony wrote: ↑Mon Sep 23, 2024 10:58 am
Sure, thanks for the replies. Sounds like if I use loctite, ring dings, cotter keys seizing wire and left and right threaded nuts I should be fineseriously though thanks.
In comparison to mine, yours is cranked down waaaay tighter, so your actual forestay must be longer than mine. If my turnbuckle was like yours, there would be no way that I could pin it in place.
