26M Prop Suggestions
adudinsk
I just repowered to a Suzuki DF60A. We will be doing a prop test run on June 13th, dealer will be bringing a selection of props.
He asked me to post and ask people for prop suggestions and comments (dealer is great that way)
He will be starting with an 11x13 prop.
Any suggestions? Comments?
All would be app.
Regards
A. Dudinsky
All would be app.
Regards
A. Dudinsky
- NiceAft
Re: 26M Prop Suggestions
This poster has an
, so the boat bottom is different than your
, but I hope this post from a year ago is of help.
Well, my re-power is complete. After much research and discussions with BWY, my marina, and he folks re-powering the boat (Suzuki dealer), I went with the Suzuki DF60AV four-stroke with a 14x9 prop, replacing our old Nissan 50D two-stroke. We tested a wide range of props on the boat, ...
Ray ~~_/)~~
My Suzuki DF70 is spinning a 11x13 prop I believe on my 26M. I'll take a look and see if that's correct.
That turned out to be the best for MY boat. BWY had a slightly higher pitch original prop which I believe was best for sea level salt water. I'm at 4,000' fresh water.
- ris
We also have a 14X9 on our Honda 60 which pushes our 26X (know yours is a M). This gives us our best high and low speed fuel mileage. We tried a 14X7 but the 9 works better.
adudinsk
They are starting with an 11x13 for the prop test.
Should I test ballast in or out?
Oh.. will be in fresh water (Lake St. Clair mostly)
Thanks in advance
AD
Thanks in advance
AD
- kurz
Test must go like this....
Ballast out...
Motor must get 5500rpm.
If not go to smaller prop....
If it goes for over/near 6000 get bigger prop...
Ballast out...
adudinsk
We put a 11 1/2" x 13 pitch.
Fresh motor revs to 5500rpm, was told that after break-in, we may get 100-200 RPM more...
Happy with performance..
AD
AD
What is the motor's MAX RPM at WOT?
I'm not getting max but close enough. I rarely run WOT anyway.
- Be Free
Sounds like a good match to me. I'd be happy with those numbers.
Bill
2001 26X Simple Interest
Honda BF40D
Honda BF40D
