I did see a 2000 Catalina 250 for $20,000. There must be some reason there is a $12,000 difference.
Some folks have complained about the boats being "squirly" under power. The only times I've noticed it was when I was running near hull speed in a messy chop, never above hull speed.beechkingd wrote: ↑Thu Jan 01, 2026 10:12 am With the 30 I could see it drain at about 8-10 MPH, some would empty below that but not much. It was a real handful trying to keep it straight at that speed with the rudders up!
With the 90 it would still do 21-23 MPH with the ballast in, no need to spend time emptying to get away from shore. It's also 100x more stable with the ballast full vs empty and the mast up, I never trusted it empty unless the water was glass smooth. Certainly wouldn't pull a tube with the mast up and the ballast empty doing tight circles. Efficiency vs stability isn't something I wanted to play with, it certainly was fun when I had it.
Trading for a monohull with a lead keel is such an improvement if you actually just want/need to sail.
Great point.Be Free wrote: ↑Fri Jan 02, 2026 8:08 am it does take a lot more skill to get my Mac to perform half as well as my previous sail boat. I enjoy the challenge and I enjoy sharing what I've learned about using getting the most out of our boats. I think that is the case with most of the long-term owners on this site.
Looks stern heavy in the pic to me. I got the bare boat Easy described above in 2024, original (195#) Nissan 50 two stroke centered on the transom, 200# captain centered on the seat in front of it. Just one 6 gallon gas tank in the starboard cubby (40#) while the (unspecified weight) first mate tended to sit port side while motoring, then both of us opposite the sail when sailing. A 37# start battery under the port aft seat, 37# porta pottie in the head starboard, and a Danforth in the center bow locker.leefrankpierce wrote: ↑Wed Dec 24, 2025 2:32 pm Here is the only picture I have that might show how it sits.
I suppose I could add ballast to the nose and see what i think.
Recently I was into my front most compartment under the bed, will have to remove some foam.
Play sand?
Anone have better idea?
