MacGregor 26M Blog – A Beginner’s Journey
Re: MacGregor 26M Blog – A Beginner’s Journey
I like to support Blue Water Yachts when possible. However, shipping to Greece might be expensive.
I am sure you can purchase a mast hound locally. I found this one in Europe. Kurz has sourced one in Europe.
https://nacrasailing.com/product/mast-hound
I installed a second mast hound ABOVE the forestay. This is necessary so it does not interfere with the head sail.
I have a simple line from the new mast hound above the forestay down to the bow pulpit where I tie it off with a simple knot.
Once you replace your bent spreaders with new straight tube, your boat will be strong and safe. You may be able to see the angle the spreaders are raked back.
click to enlarge
Agi
Post by Agi »
Thank you @Russ for sharing these pictures. Your MacGregor is in a really good shape :) and I like the idea for the extra safety.
I ordered yesterday from Blue Water Yachts the spreader and several other small things.
You are right! I want to support too. It is really great that we have the possibility to order the original ones, even if it is more expensive for me becauses of shipping and custom clearance I prefered it to do it this way.
I will keep you updated, as soon as they will arrive and when I will the adjustments.
Thanks a lot again to all of you!!!
Good to see you are repairing your spreaders.
Now is the time to learn how to lower/raise the mast. Once you master that skill, you will feel more confident.
Agi
Post by Agi »
Hi everyone,
Wanted to give you a little update about my detailing :)
I am sending you some pictures after using the Meguiars Oxidation Remover. This product worked really great. I found it better than the products that I have from 3M.
Sending you some pictures about the progress. There is still a lot to do and I have to use the Polish and after that I want to wax it or use a Ceramic Spray either from Meguiars or from Turtle still think what to buy. I keep going and will keep you updated :)
Furthermore I want to ask you two things:
1. Is there everything I have to do for the toilette? The toilette has never been used, do I have to change or maintain something?
2. Today the owner told me that the outboard motor doesnt turn so far on one side, he said that it is not much just a little bit. Do you know what I could change on the construction or what I have to adjust so that amount of turning to the left and to the right sight will be the same?
Thanks in advance!!!
How old is the toilet? Make? 8)
Agi wrote: Wed Nov 26, 2025 2:56 pm
Agi
Post by Agi »
From 2008 but has never been used ☺️
Yes, but thats almost 20 years old. Check all the seals. Might be worth replacing it simply b/c of the age. 8)
Agi wrote: Thu Nov 27, 2025 12:54 pm From 2008 but has never been used ☺️
This might help with the head
https://www.waterwayguide.com/knowledge ... rine-heads
This site has the manual for your head
https://marinesan.com/jabsco-toilet-man ... fOB6qKj5ot
The next question is where is the holding tank and how is it pumped out? It looks like it is in the v-berth area.
What is the turning difference with your motor? Can you show a picture of the motor turned in both directions?
Agi
Post by Agi »
Thanks for replying me.
Actually I am waiting to check it as soon as the license of the boat is on my name I will update you.
Maybe another question:
Can you suggest me a rigging hose adapter that will fit for the boat? I dont like how the mechanic fixed this :(
Thank you in advance
Be Free
Post by Be Free »
I'd look for something similar to the cable boot that came on the boat.
https://shop.bwyachts.com/product-p/h002-1v0.htm
Bill
2001 26X Simple Interest
Honda BF40D
Agi
Post by Agi »
Hey everyone,
It’s been a while since I last posted here. First of all, I’d like to thank you all for your ideas and for taking the time to respond to my questions.
Over the past weeks and months, I’ve been working really hard to bring my 2018 MacGregor 26M into great condition, and make it the most beautiful MacGregor in Greece 😊. There has been a lot of work on the exterior, interior, and the trailer.
There’s still a bit left to do, but I’m almost there! That said, I guess work on a boat never truly ends.
Today, I was excited to take it out for its first ride. However, even though I had checked everything and had a full service done on the Evinrude 50hp E-TEC by a professional technician, I suddenly got a red warning light indicating no oil, despite the tank being full. The engine wouldn’t go above 1000 RPM, so I had to stop.
Thankfully nothing serious happened, but it was quite stressful and very disappointing, especially after having everything checked professionally.
I’ll be calling the technician tomorrow to figure out what’s going on.
Agi
Post by Agi »
Furthermore, there is a problem with the hose connected to the water tap. When I turn on the electric pump, the hose cannot withstand the pressure and slips out of the metal connector. Do you have any idea how I can fix this?
dustoff
Post by dustoff »
Agi,
I would just swap out that connection. It's an unusual style for a small boat water system connection, at least in North America. For soft vinyl tubing to a hard connection I would swap to a screw-on barb. For vinyl to vinyl, I would change it to a double barb connector with stainless clamps on both ends. They're cheap and easy to make changes when needed.
Dustoff
:macm:
Agi
Post by Agi »
Thank you Dustoff for your reply!
Actually I was thinking to buy a complete new shower hose.:)
I wanted to ask even something else!
Where do you have your water tank and for how much liters is it?
The floatable water tank that I have is for 150lt and it is on the left site onder the kitchen. Now it has about 80lt but I noticed that the boat has the tendency to tip on the left site if it is in the water.
How are you dealing with this?
Thanks in advance
-Agi-
dustoff
Post by dustoff »
For years I just had a small 35-ish liter tank under the starboard forward-facing settee seat. I had a small 12v dc on-demand diaphragm pump and had cold water to a hand shower on the transom and a faucet at the sink. The tank was too small to be practical, and the pump really didn't provide enough pressure for the shower. I pulled it out about 9 or 10 years ago and for a long time I just used a hand-pump 19L water storage bladder under the sink and some additional plastic water jugs (as required for a trip) stored under the seats to refill it. I actually made a cover for the transom shower and sealed it with 5200
A couple of years ago I did electrical rewiring and upgrades, so I replumbed the water system, upgraded to a 5 GPM shur-flo pump, brought the shower back to life, and added a 120L plastimo triangular flexible tank in the bow. Several people on the forum have installed these in various sizes and locations.
The bow storage area was filled with flotation foam blocks from the factory that I removed, and I made some tie-down points in the corners to secure the tank and got some netting help keep the water in there from sloshing around too much.
I'm happy with the way the boat handles with 250 lbs (113 kg) of water up there. Basically, its like having a full-grown adult laying in the bow. This actually balances things out nicely when me and my wife are in the cockpit. Being down low along the centerline it doesn't affect balance.
In the bow location you have to accept the fact that the designed positive buoyancy safety feature is compromised. I mitigated this by installing 2 bilge pumps on float switches with their own drain ports.
I also consider that the number of people on the boat for safe operation is one less with that much water onboard. If we're just going for a day trips I'll only keep it filled to 40-50 liters.
Dustoff.
:macm:
