However, I have a stupid question that wasn't addressed in the previous discussion. - Would it be possible to achieve a similar result (reduce rounding up) by shifting the COG of the boat forwardly? For example, would placing a weight in the bow, or moving cargo forwardly in the boat, tend to pitch the boat forwardly slightly and therefore move the sails and the center of effort forwardly relative to the CLR, therefore producing an effect somewhat similar to reducing rake?
If so, this might provide a secondary adjustment technique that could be made fairly conveniently while under way or sailing. For example, on our boat most of the "cargo" (crew, motor, ice chest, gas tank, etc.) are positioned at or fairly near the stern, while there is normally very little cargo midship or toward the bow. So, it would seem possible that weights, or a sack of gravel, or whatever could be placed under the forward berth, for example, to shift the cg forward slightly. - Obviously, this shouldn't be overdone, and the optimum weight and weight position would have to be determined, but it would have the advantage that the placement of the weight could be adjusted fairly easily on the water as desired or when conditions changed, assuming that you have a reasonably cooperative crew (or an autopilot).
I would be interested in knowing whether anyone has been able to improve sailing performance (relative either to pointing or other points of sail) or motoring performance by such a technique, or by simply adjusting the position of cargo, etc. In this vein, is it preferable that the boat be pefectly level fore-to-aft, pitched slightly forwardly, or pitched slightly rearwardly?
Jim Cate
