Leaks, where else does it collect?
James B
Post by James B »
I'm new to the site and the 26X. What I'm finding is water ( 2-3 quarts) in the bilge after a particularly hard rain. I'm not to concerned about the amount, but where it might collect other than where I'm looking. So far, I find it under the galley and under the table seat with the cooler. That seems to be the low point in the boat. Is there anywhere else I should look for water?
James, this has been discussed in other threads, on several occasions.
You may want to use the search facility at the top of this page before posting... gets you the information you want, and also prevents fragmenting the discussion so that future readers can find most of what they need in a single thread.
I did a quick search using the word 'leaks' and found the following currently active topics on the subject:
http://macgregorsailors.com/phpBB/viewtopic.php?t=4356
http://macgregorsailors.com/phpBB/viewtopic.php?t=4309
http://macgregorsailors.com/phpBB/viewtopic.php?t=4064
I would recommend that you re-post this question under the first existing thread for continuity sake.
James B
reply
Post by James B »
Thanks, how can I remove the post?
Don't bother... if the Mod's want to they will!
craiglaforce
Post by craiglaforce »
