Mast deck light
Locked
Mike A
Mast deck light
Post by Mike A »
Does anyone know if the stock mast mounted deck light has a lens or just a sealed bulb? I noticed that there was no bulb or lens cover when I got to the marina this weekend. Does West marine carrry replacement parts for it?
Sloop John B
Post by Sloop John B »
Your lens and light got blown off somewhere in transit.
If the thing doesn't come off (riveted and soldered ?) wait for advice on brand and size.
If no one answers, call Bill at MacGregor's for advice.
Mike A
Post by Mike A »
Thanks, I'll be able to give a closer inspection this weekend.
Erik Hardtle
Mast light
Post by Erik Hardtle »
I had to replace the whole lamp assembly recently.. West Marine has the exact item:
LITE-NAV MASTHEAD #2
ITEM# 174391 $19.99
There are two long screws that hold the plastic and lens assemble to the mount. It does have a replaceable bulb.
Duane Dunn, Allegro
Post by Duane Dunn, Allegro »
That is the correct replacement part number, however if I were replacing mine I would go with the Masthead/Decklight combo #174409. Costs more, but gives a much needed deck light as well. Just wire a DPDT switch in the wire just above where it exits at the mast base.
Combo Light
Locked
