Des UK
Help!!
Help!!
Des UK
- Sloop John B
Del, I was crawling around under my boat (checking trailer) and came across one inexplicable spot similar to what you describe, about as big as a hand print. Boat was wet with morning condensation and the spot rubbed off.
Sounds like your discoloration is in the gel coat itself. Oak leaves will tarnish but blasts off with pressure washer or even soap.
Might be a manufacturing defect, but Ive never heard of such. Youll probably have to coax one of your mad scientist friends over for a look.
Being in the UK certainly doesnt help for any recourse you might have with MacGregor. Do report the situation to your dealer (if you have one).
Let us know what you find out.
LOUIS B HOLUB
I had leaf and blue berry and bird poop stains after one week of storing my boat under a blueberry tree.
Solution: A small "hand held" 16 oz. spray bottle with a mixture of water, plus/minus 4 tablespoons liquid soap, and about 4 tablespoons of bleach. Mist the spots, with a hand scrub brush lightly, then rinse.
I followed up with a wash/wax automobile soap solution, and the boat looks great.
Storing the Mac under a tree is a NO NO. (Unless it is tarped).
