whiskey pole!
rick retiree
whiskey pole!
Post by rick retiree »
Senior citizen relatively new to this site and sailing so bear with my barrage of questions guys! Have installed a dozen mods from your site and have contributed several of my own and $ to this site and thoroughly enjoy it as Ive got a lot to learn. Considering using a whiskey pole with my 150% Genoa on my 2002X but cant find any in the catalogs. Can fabricate one I suppose. Any of U guys have experience along these lines? In one sailing book they suggest mounting bracket on front of mast but wouldnt that jeopardize the Genny? Tx much
Dimitri-2000X-Tampa
Post by Dimitri-2000X-Tampa »
Rick, although a whiskey pole sounds like more fun, I think what you want to search for is a whisker pole. :wink:
AWKIII
Post by AWKIII »
Rick:
Is your jenny on a furler or is it a hank-on?
You already have that Boomkicker installed? :D
PM me. I have an idea for you.
Craig LaForce
Post by Craig LaForce »
I bought a 6X12 ft Whisker pole from West marine a number of years ago for $100.
Forespar was the brand.
They are also advertised in Defender catalog. THey also have a website.
kevperro
Post by kevperro »
Forget the pole and just get the whiskey! Your sure to have a great time.
Hamin' X
Post by Hamin' X »
Have a look at this Mod:
Boat Hook Whisker Pole
Rich
baldbaby2000
Post by baldbaby2000 »
You do want to consider the attachment ring for the whisker pole. On our boat the genoa sheets occasionally get caught on it requiring someone to go forward. I have an M and it usually happens if the mast rotates before the Genny is fully across after a tack.
BB
ronacarme
DIY whisker pole....
Post by ronacarme »
For last 15+ years have used a $20 telescoping swimming pool pole to whisker out the clew of my drifter as needed. Bigger diameter than a boat hookand thus sturdier. Trivial DIY mods at ends to fix same to the drifter clew and baby stays or shrouds. Holler if you want details.
Ron
Divecoz
Post by Divecoz »
Hamin' X wrote:Have a look at this Mod:
Rich
Hey does that thing work well??? I LOVE the concept! If it works well we must have some smart guys on this board . . . NOW Scott how about that custom A/C bud?
Dave X2000 Jac
Post by Dave X2000 Jac »
Hello Rick,
Just this summer, I built a whisker pole very similar to the Mod posted. I went to Lowes Hardware and bought 6-12 foot heavy-duty painting extension pole with a roller thread on the end, a new paint roller, a "U" bolt, and a brass clip with a "D" opening on the other end. I cut off most of the metal end of the paint roller and bent the remainder into a "question mark" shape and filed the end smooth. That was screwed on tightly to the end of the extension pole and fits through the jib clew (metal ring on the floppy end). In the handle of the extension pole, I drilled two spaced holes for the "U" bolt. Before attaching the "U" bolt, I slipped the "D" end of the brass clip onto the "U" bolt. I mounted the "U" bolt, and I was done. The total cost was about $55. It worked just fine for both the 150% Genoa and the asymetrical spinnaker (light air). A friend took two great pictures of it in action, but I'm not technologically astute enough to post them here. It easily clips onto the mast ring for the lower connection of the boom vang. Positioned under the life line, it holds the genoa sail in precise position. For keeping the sail even farther out, the whisker pole clips onto the lifeline. In that position the sail moves up an down significantly, but it still catches lots of air.
That's about it,
Dave "Jac"
Bill at BOATS 4 SAIL
Sailboat: MacGregor 26D
You can use whiskey for ballast.
Hamin' X
Post by Hamin' X »
Bill at BOATS 4 SAIL wrote:You can use whiskey for ballast.
My favorite ballast is Wild Turkey 101.
However, there must be some slop, or some other problem in my ballast tank, because when loaded with the stuff, the handling of the boat becomes erratic. :o
Just kidding. Don't drink and boat.
Rich
Rich Plumb
Boat Hook As A Whisker Pole
Post by Rich Plumb »
Here in Puget Sound, we often find ourselves sailing in channels where the wind is dead ahead or dead astern. A whisker pole is very useful. My boat hook whisker pole is still working great. Here's a recent picture of it in action. Notice that the ring on the mast is at the same height as the two halyard cleats on the 26X mast. Good luck!
~~~~~~~~~_/)~~~~~~~~~~
Rich Plumb, "Plumb Crazy"
26X, Covington WA
Duane Dunn, Allegro
Post by Duane Dunn, Allegro »
My forespar 6/12 adj works great with my 150 genoa. I have the version with the spike on the outer end which I like better than the clip. This makes it basicly the same as Rich's with his paint roller handle spike.
My mast ring is mounted higher, about half way up between the mast cleats and where the baby stays attach. This makes my pole level when the genny is fully unrolled. I think there is some variation in sails so you should find the mounting point that matches you particular headsail. I think my headsail may not be stock.
pokerrick1
Sailboat: Venture 23
Turkey 101
Post by pokerrick1 »
[quote=
"Just kidding. Don't drink and boat".
Rich[/quote]
Please tell me that's not a real rule - - - is it??? :?:
Rick :?: :macm:
