Pedestal Guard for 26m
- ssichler
Anyone install the pedestal guard from BWY on their 26M?
http://www.bwyachts.com/web%20catalog%2 ... _guard.htm
- richandlori
- richandlori
My pedestal does not have the pole mount.
The guard is very solid and installation is pretty simple. You just gotta drill four holes... The supply the nuts and bolts.
My only caution would be that you are bolting this thing to the pedestal, which is just secured by that ring flange at the bottom. So, any force you apply to this guard is at the end of an about 4 foot moment arm, with respect to that flange.
The bottom line is that it is a good "light-duty" handhold. The best you're likely to get. But, I'm afraid of putting alot of force on it, 'cause too much will just snap the pedestal right off...
- ssichler
This is a picture of my pedestal now:
I agree with Rich that one should be standard a Mac. All other boats my wife and I have sailed on have them so we keep on looking for a secure handhold when crossing from one side of the boat to the other like after a tack. I would hate to accidently grab the chartplotter if I slipped. Thx for the feedback here.
James V
How high above the pedistal does this go?
I would like to put a chart plotter and a forward sonar there. I may have to go side by side.
- David Mellon
I used two cutting boards from Wallmart, cost about $2 each. I know it looks a little cheesy, but it gives a very solid grip. I will dress it up someday with trim along the outer edge. It is held down with three 1/4" bolts. I put a channel in between the two boards for wiring. You could size the board for the units you plan to install, and for the price you could try a few configurations. I would suggest that side by side installation may make it more difficult to get around the pedistal. If you find a nice stainless grip please post it, l could trim the forward end and install a taller grip. This grip while solid is quite low.
I have the same pedestal on my
which I converted to wheel steering I bought pedestal guard feet kit, it will take ss tubing from 7/8" to 1 1/4 " at WM $54.00 Can. I bought 1" ss tubing for $25.00 Can . I'm now in the process of making my own pedestal guard will post pic's when finnished but right now I dont know when that will be "Busy"
John
John
- Terry
Grab Handle
DLT wrote:
That already happened to me during shore/land rigging when I was about to launch, suffice to say launch was cancelled and I had to order a new pedestal which was covered under warranty. The new one is a bit beefier and I may get the handle some day but I will keep in mind "light duty" only.
