That's my
I know you could'na see for the fog Laddie
Phone rings you pick-up the phone same time as your wife a voice say's is the coast clear
so you like the mac 26s yawl
John
My shrouds were also left too short when I replaced Roger's verniers with Sta-master adjusters. I cut his vernier channels into spacers, each about 4 inches long, to make up the shortage. My second attempt was a bit more refined cut (bottom pic, fwd). I used cutoff disks on a RotoZip, followed by a rotary file.Dimitri-2000X-Tampa wrote:... Bottom line was that the mast was too straight up to attach the upper shrouds. I had to back the turnbuckle off about a half an inch to get them attached. After doing that, the pendant was dangling about 1 foot back with the additional bend that the upper shrouds added. This will probably be ok, but there is no more adjustment in the shrouds, I may take the turnbuckle back in but there is already 250#of tension on the uppers and I haven't tightened the lowers yet. I'll do that today and that will probably bring the uppers back to 300# where I used to have them. . . .
The net result is a much straighter mast than I used to have and with somewhat less bend too (haven't figured that part out yet)...maybe I used to have too much bend before. The litmus test is when I take it out sailing and hopefully have a lot less weather helm than I used to. I used to have my rudders probably 30 degree deflected just to keep it on track with a 15kn wind...that was way too much.
