engine vibration at higher rpm
tidalwave
Post by tidalwave »
I have a 4-stroke 60HP MERC BigFoot with an 11 pitch prop. At higher RPMs, (above 3500), I start getting noticeable vibration from the engine.
Below 3000 RPM there is almost no engine noise and no vibration.
Am I getting cavitation? Do I need to go to a 'longer' pitch on the prop?
Chip Hindes
Post by Chip Hindes »
Never heard of vibration being caused by the wrong prop; vibration is narmally caused by a bent, dinged, or unbalanced prop or a misfiring cylinder.
Night Sailor
Post by Night Sailor »
I'm with CHip. Bent prop or misfiring engine. Ventilation or cavitation would be noticeable immediately with higher rpms from the engine, too.
royntracey
Post by royntracey »
I'm betting Chip's right, I hit a small rock (ever so slight dent) then got vibration at high RPMs. A guy (with a smallfile) at the marina sorted it in around 5 mins.
Been good ever since.
