I have heard it said many times by Mac X and M owners that when the sailing gets tough, they are delighted to be able to rely on big horsepower to get home. I have a Mac classic and that is not an option for me.Frank C wrote:Eric, You joined this group too late to see the thread that (partially) described his 10 years on Zeno's Arrow. Since Mike Dunn is an infrequent visitor it could be some weeks before your answer arrives. You may want to grab some background reading in that linked thread.eric3a wrote: . . . being out in 70+ knots in a Mac is another story! More details please.
delevi wrote:Mad Mike's adventures on his Macare certainly remarkable and his skill is probably more a testimony than the boat itself. Most of us, however, would not take on an ocean crossing in a Mac. . . .
A few points on heavy air sailing on a Mac. In my case, since I face heavy winds with such frequency, I decided to make a number of mods to deal with the conditions. First, I want to say that the rig must be tuned to get rid of as much mast rake as possible. I had my original forestay turnbuckle cranked all the way down. This helped a lot. I recently replaced the forestay with thicker wire 5/32" and had the stay cut 2" shorter than stock. This helped even more. If you don't seriously reduce mast rake on a Macyou will be constantly rounding up into the wind in anything 20kts+ . . .
When the waves get high, the outboard, (a long shaft version) comes out of the water half of the time and is effectively useless. Others with a 10 hp and less on the transom will relate. I find myself wondering whether the prop of the big motors can be relied upon in steep waves driven by heavy winds. Do they not come out of the water?
Last month I was caught not once but twice by Force 8 winds on Lake Ontario. Thankfully the fetch did not allow full wave heights to develop. In one case, I was ten miles out and faced 3-3.5 meter waves (9.9-11.5 feet) and in the other case only a mile offshore and the waves were no more than 1.5 meters. These conditions were no problem for the boat.
In the large wave situation, I deployed a parachute sea anchor which worked very well in the storm. I had one seasick crew member. The side to side motion and centerboard banging was very uncomfortable (15-20 degree heel with a fast motion). That amount of oscillation is potentially dangerous down below if you are trying to move around.
I lifted the rudder, and that helped. I lifted the centerboard but the oscillation side to side seemed faster; so I put it back down and suffered the banging.
The same day I got back, I bought 8 Davis Rocker Stoppers for next time.
I am hoping they will slow the side to side oscillations and maybe reduce the overall heel in an anchorage/sea anchor situation. I have not had a chance to try those yet.
If you carry a sea anchor, the Mac will handle Force 8 in limited fetch conditions and in truth, I think it could have taken much more. BTW, I nearly ripped out the factory deck cleat with the sea anchor. I then used the bow eye (where the trailer winch hooks on) and that worked well.
I have a 5 ft. diameter parachute sea anchor and I have no idea whether a bigger one would work better. It did what I wanted it to. It pulled the bow toward the waves. The waves struck the port forward quarter so the boat was riding in a close-hauled angle to the weather. On analysis of my situation later, I concluded that I might have been able to point the bow closer to the wave direction if the tiller had been lashed to leeward.
I had been trying to sail to weather prior to deploying the sea anchor but I could not make headway. I could have dropped sail and bare poled but the the worsening forecast indicated that the worst of the conditions had not yet appeared and I did not want to be exposed to a greater fetch and therefore larger waves.
We did continue to lose way with the sea anchor but at the rate of .8-1 knot(s) per hour instead of 6+. After a three (plus) hour wait, we had steady 20 knot winds for a perfect 25 mile beam reach home.
That was the first time I had deployed a sea anchor. Sure glad I had it!
