FLOOR STROPFrank C wrote: . . . from prior thread, Mainsheet to Pedestal - Weak Link
There are beefy L-brackets bolted to my 26X sole, and the ped mounts to them. The problem is not with the L-brackets. The problem occurs when we transfer all mainsail loads to the top of the pedestal, and then through the pedestal to the floor brackets. I have changed the pedestal bolts to 3/8" eyebolts, earlier described at Removable Traveler thread.
This all has given me a different idea for a "Soft Traveler." Watch for another thread.
Part of the motivation for my removable traveler was my dissatisfaction with Roger's anchoring the mainsheet to "the TOP" of the 26X's pedestal. A crash gybe on SF Bay is something to avoid ... but when it happens, it makes you wonder how the pedestal, and engine controls, and steering system ... survived!?
Absent my removable traveler on its oak bridge, I'd still want to add, at minimum, a floor strop through those cockpit eyebolts (mentioned above) with a beefy "floating stainless ring" for shackling the mainsheet. I imagine a 3-foot length of half-inch line, with it's ends tied to each eyebolt, and the ring free-floating anywhere along the line's center section. This would tether the mainsheet tackle at about 18" height. Roger's mainsheet boom bail is 12" forward from boom-end. For both my traveler and this plan you'd want it more like 18 inches forward from the boom-end, assuring the mainsheet and strop clear across the pedestal's front panel.
Now all mainsail forces are going through the mainsheet, then the STROP, & directly to the eyebolts at the cockpit floor.
WARNING: Know what you're doing here! A stainless ring of quarter-inch stock looks plenty beefy, but it's rating is lower than you might expect. Check it first and do your own calculus ... maybe 3/8" is better?? Further, fabricating to this concept, you would now have a heavy metal knee-cap smasher ... just about knee-high in a crash gybe. Maybe not best for novice sailors, caveat emptor!
SO ... IS THIS A SOFT TRAVELER??? Not yet.
It's just a way to avoid slamming mainsheet loads onto the top of the 26X's pedestal.
