Generators On-Board (and charging batteries from them)
- kmclemore
Agreed, Steph - I had the same thought. The only thing I can say in defense is that the cap on the generator has a vent-lock, so with that closed you won't get much leaking of vapor, and should an actual liquid leak occur the vent being closed will greatly limit the amount that can leak out. All the same, I keep mine stored under the transom seat for just that reason.Catigale wrote:Dont like that gas generator being stored in the bilge, Rich...a fuel leak would put you in a classic situation for a bad boat fire. At least you should have a fuel vapour sniffer alarm in your bilge if you are going to do this...
Honda generator, hard rubber feet
Rich,
Could you tell us where you purchased the hard rubber feet, It looks like a great idea, and I would like to do the same. Thanks Jim
Bill at BOATS 4 SAIL
- Sailboat: MacGregor 26D
flutterbye
Jack how many amps?
Jack,
How many amps does your Vector charger give your batteries when your EU2000 is running? I'm curious because I've got the same generator and charger and am looking to do something similar with mine. My first post- thanks for a great site!
Robin
Robin
Frank,Frank C wrote:Anyone want to link to their favorite sources for Honda or Kipor?
I bought a brand new Honda EU1000i for $595, including shipping, on eBay.
Here's the link, athough at some point it will die at its been over a year already...
- Tahoe Jack
- Location: Lake Tahoe Nevada 2001 26X Evin/Suz 50..'Octopus'...
Generators on Board
Flutterbye.....in response to your question...in my experience the computer in the Vector actually controls the charging rates...whether AC is supplied by AC shorepower or generator. For example, if your batts are down by one-quarter or so and you set initial charge at 30A....within minutes the Vector internal computer will reduce the charge rate..sometimes down to 5A or so. I think the generator will handle all the Vector asks for. If you are motor sailing, the motor will keep the batts up....if you are at anchor for extended time...I use the generator AC directly to cooking loads etc....and a bit more if needed to top the batts. Hope this helps. Welcome aboard.
Jack
- baldbaby2000
I store my Honda EU1000i behind the companionway ladder (on top of the battery opening) in the cabin. I close the vent on the gas and have never had a leak or smelled gas. I usually run it on the dock if we're slipped or in the cockpit being careful of the exhaust (CO plus it can discolor the gelcoat).
On disappointment: the generator does not put out the power advertized taking into account their derating formula for altitude. I bought it new.
Daniel
Daniel
Rich
I'm very happy with my kipor their is a dealer not to far from me I am a licenced mechanic to trade although I do not pull wrenches any more "except at home" I supervise those who do at my job , so fixing these things is not a problem . but I find if I can get it for the right price and I did, 10yrs from now if I have any problems with it the parts will usualy cost more than I paid for it. So I,d just go looking for another new one at the auction will most likely be better by then with newer tech. !!!!
Cheers John
Cheers John
