Posted: Wed Feb 27, 2008 9:11 am
RenegadeLease wrote:Regrade!
Discussions relating to the MacGregor line of trailerable sailboats
https://www.macgregorsailors.com/forum/
Oh, p*ss off, Ron.ronacarme wrote:I find the M vs. X comments to be mostly instructive and hence of value, particulary for prospective purchasers.
However, I can easily do without overly combative, nasty, insulting or similarly discourteous comments, on ANY topic, on this site. Plenty of that available on talk radio and TV. Luckily, we have had virtually none of that on this board. Good job, moderators. Thanks.
Ron
Nope, not much at all. Check the specs on the Honda site - I believe they're virtually the same.Divecoz wrote: I have a question too is there a big difference in Noise between the 1000 and the 2000
That is true when the EU1000 is putting out 900 watts and the EU2000 is putting out 1600 watts (their rated power, at which the 59 db was obtained). When putting out 900 watts, the EU2000 would be a bit quieter, and probably more importantly, the engine could be running at a lower, less annoying speed.kmclemore wrote:The sound levels are *exactly* the same at 59dB @ 7 meters.
RIK How would the backstay work with the rotating mast?Ric K wrote:I would edit that statement as follows: M owners would you UPGRADE to an X!!!!There is no doubt in my mind I made the right choice between an X and an M.
I was ready to purchase a brand new M, until I realized, that only the X would make the coastal cruiser I wanted.
When I get a chance I am going to post the following mods: Hot water heater, transom shower, built in chest refregerator, microwave, flat screen TV, inverter, custom Honda 2000 generator support, radar with interfacing chartploter/ GPS, and autopilot with remote control.
A lot of the mods I would not have beden able to fit on the M.
Next year I'm going to update my rig with the M's rotating mast, and I feel I will have the best of both worlds!!!!
double winkkmclemore wrote:Oh, p*ss off, Ron.ronacarme wrote:I find the M vs. X comments to be mostly instructive and hence of value, particulary for prospective purchasers.
Ron
No problem with nit-picking. Do that myself. Typically, only diesels have sufficient torque to drive a generator at 1,800 rpm. These aren't likely to be found as a portable, but there may be some smaller models designed for continuous rather than intermittent/emergency use, where the 1,800 rpm is desired.Hardcrab wrote:Moe,
Not trying to pick nits here, but the governed engine rpm is dependent on the number of poles the generator has. The more poles, the lower the rpm needed to reach the 60 hertz standard. (The rpm will be some multiple of 60).
With that said, are there any small 4 pole generators running at 1,800 rpm on the market from someone? Maybe only the bigger models go that route.
