I guessed at the mast weight and CG location, so the resulting forces are also suspect, but the geometry should be right or close to it. You can scale the resulting forces up or down based on mast weight and CG.
The mast on the
Yes, I have the 377 pound version and that is why I do not use baby stays on the gin pole - at that weight the failure point would be transferred from the baby stays to the gin pole. That's subverts the whole point of the original system using the baby stays on the MAST and not the gin pole. The MAST will never fail - it's too strong - so the original system puts all the failure possibility on the baby stays which are many times stronger than the gin pole.Tomfoolery wrote: ↑Tue Feb 11, 2020 12:44 pm Mast compression load depends on where you attach to the mast. I did this years ago using a level mast, but of course, it's not level at its lowest position.
By my calculation, the critical buckling load of the (mast)* gin pole tube (1.5" OD x .125" wall x 72" long) is around 2450 lb. Put some factor of safety on it, and it's still plenty strong, but those flared stamped sheet metal tangs at the bottom are iffy. So is the tube wall where they bolt on, though I haven't checked that connection. Putting a wooden or plastic slug, or aluminium sleeve for that matter, inside the tube at the last few inches at the bottom would be a big help. Keeping it square to the tabernacle would also, as just the slightest off-square puts all the load on just one tang.
The factory version uses the back part of the mast plate to support the bottom of the mast. If the mast falls it will bend the angle plates that are bolted to the cabin roof, not the mast or the bolt or the plate. Mastreb already proved that by trying to lift his mast with only one baby stay - the mast fell over and ruined the angle plate that is bolted to the cabin roof. All other parts stayed intact.Tomfoolery wrote: ↑Wed Feb 12, 2020 9:55 amBy my calculation, the critical buckling load of the mast (1.5" OD x .125" wall x 72" long) is around 2450 lb. Put some factor of safety on it, and it's still plenty strong, but those flared stamped sheet metal tangs at the bottom are iffy. So is the tube wall where they bolt on, though I haven't checked that connection. Putting a wooden or plastic slug, or aluminium sleeve for that matter, inside the tube at the last few inches at the bottom would be a big help. Keeping it square to the tabernacle would also, as just the slightest off-square puts all the load on just one tang.
Thanks for the mast baby stay comment. I'm pleased with that result.
