Russ wrote: ↑Sat Jan 25, 2020 6:03 am
Nice welding skillz.
I've always had the same concern. That gin pole bracket is very wobbly and bends. If you figure a way to make it stronger, post pics.
I found eliminating as much slack in the system helps. But as you said, when the mast is low it has the most slack because of alignment issues.
Is that shackle part of your mast raising system.
Also, that mast crutch is awesome.
Lost my MIG and stick welders in a fire. Always wanted to try TIG, so replaced them with a dual function TIG/stick unit. I really like TIG. I originally learned on an oxy/acetylene rig, so TIG is somewhat intuitive. There is virtually no noise or spatter. If I can do it, it's got to be pretty easy.
Will post pics if/when I modify the gin pole brackets.
The snap shackle isn't part of it yet, but could be. I haven't looked at the probable loading yet, but if the numbers work, I'll use them. I think they are rated at 300 lbs, but need to verify. I still don't have the garage cleaned up since my house fire, so I tend to store extra bits where I won't forget where I put them. The one in the foreground is currently connected to my Raising stay - good eye!
Thanks for the mast crutch comment. My projects tend to breed projects. When I built my furler support, I realized that the rotating mast would just flop over on my old mast support - causing grief while mounting the furler support and stowing the furler. So I built a new one with a v-crotch to help hold the mast in the vertical position while I'm securing the furler support and furler. All of this falls under the umbrella of reducing my setup/takedown time and effort. Before, I had to put a ratchet strap around the mast in the cockpit area - near the rear Support roller to hold the mast still. That meant leaving the work area on the foredeck to secure the mast - costing me extra time and effort.
I had a chance last night to pull a string through the mast pivot bolt holes and check the new alignment. I got it nearly perfect, so if I haven't made a gross error in judgement (Tomfoolery will certainly let me know if I have...), the Raising stay tension should be consistent throughout the raising movement.
Still have the lifeline/spreader situation to work out. Currently, I unpin the spreader from the pivot point, lay it flat on the lifelines and bungee it to the lifelines. Think it may be quicker to drop the lifelines and leave the spreader connected...
Thanks again for the comments, and if you see anything stupid, don't hesitate to point it out. As my daddy always said, I'm not the sharpest knife in the drawer.
