I have normally kept the boat on a trailer in mast-up storage. This year I may have the opportunity to keep the boat at a mooring point. I've never done this before so I don't know what is the most common way to attach the boat to the mooring ball.
I have a 2006 model
What is the recommended way to attach the boat to the mooring ball? (primary line to the bow eye or primary and secondary lines to the bow cleats)
What is the recommended size & type line to use?
Should the bow eye or the bow cleats be re-enforced? Should the standard bow cleats be replaced to accomodate heavier lines?
I have read in the threads that the boat will "hunt" or sway back `n forth in the wind. What can I do to reduce they sway at the mooring point?
And finally, what is the minimum water depth that any of you would moor your boat in & do you do this with water ballast in or out?
Thanks in advance ...
Paul
