Rudder rope replacement
Hi - I need to replace the worn rudder holding ropes on my 26M: never done it..... is there a trick to it? They should feed through the transom hole form the top - right?
Does anyone know the spec/size of the rope?
Thank you.
Thank you.
- c130king
Stephen,
When you say use bungies are you talking about replacing the line that holds the rudders down with a bungee cord? Are you able to "disconnect" this bungee somehow when you pull the rudders up?
I noticed on Bastonjock's
that he had one line for the rudders with one end tied to pull it up and one end tied to pull it down. On my
(not sure if that is standard) I have two seperate lines.
- RickJ
- Sailboat: MacGregor 19
Jimc130king wrote:I noticed on Bastonjock'sthat he had one line for the rudders with one end tied to pull it up and one end tied to pull it down.
The single double-ended rudder line is standard on the
If a rudder runs aground the bungie stretches allowing the rudder to kick up. It works, I tested it (not deliberately
Cheers, Rick
- Matt19020
EMPET- I just replaced my lines.
The lines I took off were were 12' exactly. From what I remember they were about 12 inches longer when the boat was new I thought there was too much slack in the line and I cut some off but I would NOT go any less then 12'. I replaced the line with one size smaller which I beleive was 5/32 (I had some new line from a previous boat). It may be a little tight to tape a replacement line of 3/8 and pull it thru. You may need to pull a string thru and then the new line but you should be able to figure it out as you go.
I also used the pulley system (see pics) to make it easier to raise the rudders but if you do this you will need to add at least 4 feet of line to your tally. I hope this helps.........
[/img]
[/img]- pokerrick1
- Sailboat: Venture 23
Lazy
I like the pulleys Matt - - - but I hope I never get that weak (or lazy) that I can't pull up the rudders from a dead stop as they are
Rick
Rick
- puggsy
- Sailboat: Venture 25
RUDDER ROPE
Just a thought...I've just fitted two pulleys to each rudder. Sorry i have not been able to sort out any pics of it. A short 12 inch line is tied off to the rudder. Ar the high end is the pulley, on a sewn loop. Another line comes down from the fixed cleat, through this first pulley, then up to another pulley mounted just below the top pipe rail of the rear guard rail, through that then down to the cleat again. effort is now a downward pull and the arrangement keeps the ropes out from the transom a couple of inches. One advantage is that the pulleys are clear of the water.
Its now very easy. Puggsy 06
- Matt19020
Empet, The Delaware River as far as I know would not be considered the "sailing destination" of a lifetime however it suits me fine. I have gone about 7 miles North and about 20 miles South (by motor) My home port is Neshaminy (State Park) Marina.
It is not like the Chesapeke but I love going out for a sail after work and the best part is I live only 10 minutes from the marina. The pic below was a pretty busy "sail day" in October last year.
I usually only cover about 3-5 miles one way when I go out ...the current can be strong at times but I would call it more annoying then troublesome if you are trying to beat against it.
