Macless Pete wrote:How far out does the
stern go from the rear bunks in the stock trailer?
I have been calling around for tandem trailers and this is what I get:
1. Venture VATB5925 for boats 23-24
2. Continental A2450 for boats 24-25
3. Ace trailer design for
based on trailer for boats 26-28
I would assume that you would want the rear bunks to cover as much as possible, but if the boat has to stick out what shoud be the max with a near 300 pound OB?
Thanks
I just purchased a LoadRite Elite Aluminum Bunk Trailer for my 26m which should be very similar to the 26x as to how it sits on a Bunk trailer. The model number I purchased is LR-AB27T6000102LTB1. I looked this over a lot before purchasing and found 2 major issues. On the Venture (and most others) they have a 4" by 8" or 6" by 8" bunk. This will not flex to conform to the slight curve in the Mac hull. I verified this by looking at at 26x on a Venture trailer before I purchased. Though this will still work, you have a lot of bunk that is not providing support. The LoadRite Elite has bunks the will conform to the hull. The LoadRite Website is
http://www.loadrite.com. Look at the Elite Series to see the bunk design.
The second issue is that the Tandem Axle standard bunk models will increase the load height meaning you will need deeper water to load. I am still working on getting the new trailer setup correctly, so I still have more work to do before I know the final numbers.
Here are some pictures of my 26m on the new trailer.
If your current trailer is still in good shape, you might want to add a second axle to the trailer instead of purchasing a new one. In hindsight, if I knew I would increase the load height, I would have added a second axle to my trailer as there is nothing wrong with it (I just plan to travel 400 miles one way several times a year and wanted the second axle for security).
The Mac Trailer is 21 feet from Bow stop to rear of trailer. You can go with a shorter trailer than the one I purchased because the bunks on the new trailer will extend past the end of the trailer. You do want to pay attention to the max and min distance from Bow stop to end of trailer. A lot of the trailers they say will fit the 26m or 26x are 17 feet from Bow stop to end of trailer, so the taillights will be 9 feet from the end of the boat.
PM me if you have more questions, I might be able to help you out.
Good luck;
Chris
