Help! my wife hates ring-dings.
Does anyone make a kit to eliminate ring-dings on a MacX ? They appeal to my cheapskate nature but my wife has a hard time with them. I'm sure I could replace them piece by piece, however I'm not excited about 20 trips to West Marine.
- bjmeunier
Re: Help! my wife hates ring-dings.
Twinkies are pretty good...
....jk, I don't like them either so I'm curious to see the responses
LOUIS B HOLUB
I've learned to handle ring-dings, and making sure of lines, wires, secured properly myself. My wife won't secure lines, or mess with ring-dings. I'm better off that she refuses...(that way, when/if an error occurs...I can take the blame). -- so far, no errors
If your better-half helps with rigging, and ONLY complains about ring-dings, I think I'd up-grade to whatever makes her job easier. You're very fortunate to have a helpful, willing, better-half "deck hand"...
Happy Sailing ! ! IF she 'aint happy, the entire boat is unhappy.
- Don T
Hello,
They do make ring dings that are easier to put on and take off, they have a sharper bend at one end that lets you just turn it into place.
- robbarnes1965
- Doug W
I found it easier to replace the tiny ring dings we larger diameter ring dings.
I replaced some nuts with ring dings on some of the rigging/derigging preps my wife has on her checklist..this way she doesn't have to struggle with my tools-which i am apparently not good at sharing--especially if a tool is not used correctly...
- Don T
Hello,
I do not recommend using cotter pins in place of ring dings!
- pokerrick1
- Sailboat: Venture 23
- pokerrick1
AbsolutelyQuébec 1 wrote:You let your wife touch your ring dings?
Rick
- pokerrick1
Me neitherDon T wrote:Hello,
Rick
So I'd have to guess she was'nt A Ring Dinger !!!!!!!!!!!!!! ?pokerrick1 wrote:robbarnes1965 wrote:I just changed wives.
Me Too![]()
Rick
- David Mellon
If properly maintained these work Great! I use them for the mast raising system, spreaders (which I remove for trailering) and the forestay.
