Replacing pivot pin rubber seals
js_bandit
Post by js_bandit »
Hello!
I am a newbie sailor and I recently purchased a 1994 MacGregor 26S. I was wondering what the best thing to replace the rubber seal attached to the pivot pin is. Mine are worn out and it is causing my water ballast to leak from the trunk. Will any standard rubber seal from a hardware store do? Any advice or info would be greatly appreciated! Thanks!
- John
