Radar Reflectors. Homemade DIY or purchase
WASP18
Post by WASP18 »
I removed the mast and we'll be in a MacTrawler mode for the rest of the season. For this reason, I built a radar reflector using aluminum flashing as material. We'll be cruising an area not far from a shipping lane (or channel). After reading up on the subject, a fiberglass boat is stealth-like unless there are metal surfaces like a tall aluminum mast. Yet a mast may not show up on a ship's (or yacht's) radar return. For a white "steaming" light, I mounted a three foot vinyl fence post where the mast would go. The radar reflector will slip over this stubby mast. I fabricated and mounted a bunch of aluminum triangles (flashing material) perpendicular to each other to a plastic wastebasket purchased from the Dollar Store. Cut a hole in the bottom of the basket where it will slip over the vinyl mast. Cost of materials was $14.95 for flashing and $1.00 for the waste basket. I also used aluminum tape to connect the triangles.
Here's a study at U Maine on the reflector subject related to kayaks.
http://www.seagrant.umaine.edu/files/pd ... refppt.pdf
kadet
Re: Radar Reflectors. Homemade DIY or purchase
Post by kadet »
I read an article awhile ago in one of the cruising magazines that did a comparative test on a bunch of passive radar reflectors. Conclusion was they are a waste of money as they do little to improve a yachts radar return, a dinghy outboard mounted on the rail often was a better reflector than most of the commercial units tested. The only systems recommended were active reflectors that transmitted a return electronically.
Not having a mast your plan maybe better than nothing then again it may be just as bad as having nothing. If it is that much of a concern to warrant the effort building a reflector why not get an active reflector, or an AIS transponder for half the cost, what is your life and boat worth?
WASP18
Post by WASP18 »
kadet wrote:I read an article awhile ago in one of the cruising magazines that did a comparative test on a bunch of passive radar reflectors. Conclusion was they are a waste of money as they do little to improve a yachts radar return, a dinghy outboard mounted on the rail often was a better reflector than most of the commercial units tested. The only systems recommended were active reflectors that transmitted a return electronically.
It has been said that radar reflectors are like a religion, the more you believe in them the better they work. 8)
Did you read the U.Maine test results?
Divecoz
Post by Divecoz »
If you can copy cut and paste that test Wasp.. I too have read test reports saying passive reflectors add little " visability " ... It " seems" to me like another industry manufactured from nothing , so to speak.. Radar , Lightening Protection, Radon etc etc
Whipsyjac
Location: White Rock, B.C. 96 26X Hull#486 96Merc ELPT 50HP 4 Stroke
Post by Whipsyjac »
I just clicked on the link and its more of a pdf of a power point slide show than a text report so I doubt it can be copied and pasted into a forum post.
It was very interesting but I didn't find it completely helpful. Apparently a homemade tinfoil hat thingy(no description of build process just one picture) gives the most consistently strong results over distance. The second place for distance seemed to be a flag on a pole(no mention of any metallics in it).
I agree with the post that if you want to be visible go AIS. We learned about it in our radio class, there are dozens of free apps for iPhone and Android to let you see vessels. You could be transmitting AIS which is a legal requirement for commercial vessels for a few hundred dollars, and you don't have to wear a foil hat! :wink:
Willy
JohnCFI
Post by JohnCFI »
Which is all very well, except in my opinion, the greatest danger comes from those unlikely to understand or use either AIS or Radar..
WASP18
Post by WASP18 »
Divecoz wrote:If you can copy cut and paste that test Wasp.. I too have read test reports saying passive reflectors add little " visability " ... It " seems" to me like another industry manufactured from nothing , so to speak.. Radar , Lightening Protection, Radon etc etc
Link http://www.seagrant.umaine.edu/newsroom ... s/20050524
Here's an excerpt from this link which is a press release:
"The most important discovery was that kayaks one mile from the radar platform are rarely visible on radar, whether or not they have radar reflectors. However, results changed under a mile where the presence or absence of a radar reflector mounted on the kayak or kayaker made a difference. Considering that a motorboat traveling at 15 knots covers one-quarter nautical mile in 60 seconds, this may make the difference between boater safety and an accident."
The foil hat had the best results according to the testers. The height and shape of the hat made the difference. My contraption actually (and coincidentally) fits on my head. :) It also has sharp angles, is larger and bulkier, and could be a hazard which is a problem for a kayak according to the study, but not a problem sitting on the stubby mast of my X. kayaks are as low (and below) as a wavy ocean surface. They are part of the clutter shown on the screen and yet are detected under a mile from the radar. Once I get on the water, I'll see if I can get pinged by my boating friends at the club. I'll then report back with the results.
WASP18
Post by WASP18 »
Here's a link to the complete report.
http://www.seagrant.umaine.edu/files/pd ... 5raref.pdf
kadet
Post by kadet »
A kayak is very different from a boat such as a Mac or other GRP yacht it is close to the sea and has very little other reflective properties so in this case a reflector would be an improvement.
From the yachting monthly report.
Interference is a fundamental problem with radar reflectors. Most objects will reflect radar waves in some way. The sea itself has good reflective properties. A boat is made up of a multitude of reflectors – from engine, to stanchions to the cooker (neither GRP nor aluminium masts tend to give consistent echoes) – all of which can disturb the path of a radar pulse. Putting a reflector near other sources of reflection (ie. the boat) therefore induces interference – which can unfortunately be either positive or negative
As I said if you believe that your home-made reflector helps and is all that is needed by all means install it, you are the captain it is your choice. Personally I would want an AIS transmitter so the big boys see me, know my course & speed and name so they can call me on VHF if necessary and I can see them etc.. My point is if you are concerned enough in the first place to go to this effort then there is obviously some risk you are trying to mitigate so it is a risk management decision you must make. I looked long and hard into this awhile ago and decided on neither as we don't have fog, the shipping channel here although busy is easily navigated to keep out of the way of the commercial shipping, and I don't go out in bad weather and the risk did not justify the expense for AIS which I concluded was the best option after looking into the alternatives. You may decide something else, I was just trying to point out that your home-made reflector may not operate as intended.
WASP18
Post by WASP18 »
kadet wrote:A kayak is very different from a boat such as a Mac or other GRP yacht it is close to the sea and has very little other reflective properties so in this case a reflector would be an improvement.
Your lecturing tone would be applicable to one who is foolishly operating within a busy traffic area at a major seaport. Sort of like a Piper Cub mixed in with jumbo airliners and exposing oneself to severe wake turbulence in addition to a potential mid-air collision. This is not the case and I'm not foolish. My operating area is similar to yours, and in most cases, we'll be out of the main shipping channel and would cross it only if the WX conditions are VFR so to speak.
I'm well aware of the AIS benefits and the engineering concept upon which it is based. The concept is quite similar but not the same as an interrogator/transponder system, IFF (identification friend or foe WW II design) or CAS (Collision Avoidance System) on board most commercial aircraft operating IFR, yet it produces the desired results of identification with precision. Ironically, pilots call the CAS a "Fishfinder".
Fabricating my ugly $15.00 contraption and testing it under ideal conditions with boating friends is certainly not a risk. If it proves successful in a limited way, and I expect it might, I would not place my life in jeopardy by cruising around and mixing it up with the big guys. If we eventually find ourselves cruising more often under conditions that would cry out for more safety with a AIS, then we'll buy one. Meanwhile, we expect to have fun in discovering whether this miniature aluminum train wreck mounted on my stubby mast actually works.
 ! kmclemore:
Guys, can we just cool it a bit here? Remember, this is supposed to be about helping each other as fellow sailors. Please don't make me start deleting crap and sending emails... I'm tired and not really in the mood..
At the risk of wading into a topic that's got people's ire up for various reasons, I was an electronic warfare technician in the Navy whose job was to create both real and artificial radar reflections for the purposes of obscuring or revealing ship's position.
The problem with all purpose-built radar reflectors is that they're optimized for specific radar frequencies, for exactly the same reason that antenna lengths are optimized for different frequencies: Full, half, and quarter wave sized reflectors are much "brighter" than non-harmonic sizes. Reflectors that are smaller than an actual boat rely upon that principle to appear much "brighter" than an object of that size normally would. I've been involved in testing reflectors the size of a MacGregor that show up as large as a 500-foot warship to specific radar seekers (homers, actually).
Commercial radars typically operate in the I and C bands (9GHz and 3GHz) but new bands have been released for commercial use by the military (E band) and new radars are being built in that frequency range. Very larger ships may use radars operating as far down as 900MHz.
No single reflector is going to reflect all of these frequencies equally well. A reflector sized for I band is going to be invisible to C and E band radars, for example, and the problem is that you really don't know what radars all the ships around you are using. While it's generally true that larger ships operate multiple radars, and that most commercial ships operate an I-band navigation radar, you simply never know how a reflector is actually going to appear to every different ship in the harbor. Navy vessels, for example, rarely use an I-band when entering or leaving port--they're far more likely to be operating an E-band radar for navigation.
I believe the problem is intractable enough not to bother with. AIS will be seen by any ship large enough to accidentally not see you, and yahoos in stink-pots doing 40 knots aren't looking at their radar (or anything else) as they go.
Just my two cents as someone whose job it used to be.
Ormonddude
Post by Ormonddude »
With results like this - Image I have made up my mind its FOIL HAT TIME! :D but seriously my PO installed a Davis 152 I am leaving there simply because it strikes up a lot of conversations from people wondering what the hull it is and i now have new found respect for the foil hat guy that hangs around town looking like a loony 8) We need a foil hat smiley :|
kadet
Post by kadet »
I We'll be cruising an area not far from a shipping lane (or channel). After reading up on the subject, a fiberglass boat is stealth-like unless there are metal surfaces like a tall aluminum mast. Yet a mast may not show up on a ship's (or yacht's) radar return.
Sorry if I misread this but it sounded like you were wanting to alleviate a risk, and you were making some wrong assumptions about GRP yachts from my own research. I did not ever say you were foolish nor intend for that to be insinuated, you seem to have a handle on what you want to do, you are going to test, so good luck to you. I thought you were asking a genuine question and wanted advice on what we as members of this group thought of homemade reflectors. As I had done some research in this area I thought I was providing information to you to be helpful which is why I am on this forum, to give and receive advice from fellow sailors. I also work in the electronics and technology field so maybe biased towards AIS.
Nough Said
Hamin' X
Post by Hamin' X »
 ! Moderator Note:
Folks, religion and politics are third rail items on this forum and are not allowed. Personal attacks WILL NOT be tolerated.
I have cleaned up this topic and expect that it will remain that way. If any further problems develop, there will be penalties to the offending posters, regardless of who "started it" and what the intentions were. I suggest that everyone take the time to review the forum rules posted below.
This closes the subject and there will be no discussion on the open forum about what happened, or what was intended.
~Rich---Hamin' X~
Discussion Board Policies and Expectations
Postby Heath » Thu Feb 09, 2006 8:17 pm
The MacGregorSailors.com Discussion Board is here to provide a place for MacGregor/Venture owners and enthusiasts to meet and to discuss topics relating to MacGregor/Venture sailboats and sailing in general. Most people have a common sense feel for what is and what is not appropriate in our forums and most board members generally do a great job of policing themselves. We do, however, need to have a few set policies for everyone to refer to when the need arises.
Board Member Expectations and Guidelines
Respect the Discussion Board Administrators and Moderators. We provide a service in our free time to keep the forum running efficiently. We will occasionally ask for input, but in some cases we will not, please respect our decisions. Also, we do edit for content, if you have an issue with our moderation, please contact the Administrator or Moderator directly. Posts to the Discussion Board questioning or complaining about Moderator or Administrator activity will be deleted.
Profanity: Mild profanity/swearing is allowed in the context of general speech. Explicit profanity/swearing is not allowed, and under no circumstances will we allow any profanity to be directed toward another person. Posts containing profanity may be edited at the discretion of the moderators.
Flaming And Condescending Messages: Messages personally attacking, calling names, or otherwise harassing or being condescending to another forum member or any ethnic or religious group will be edited or removed based on the moderators decision.
Adult Content/Violence/Illegal Activity: Messages containing sexually oriented/violent/illegal dialog, images, content, or links to such will be deleted. Messages with links to or suggesting illegal activity will also be deleted. These actions could result in a ban.
Thread Drifting/Steering: Please keep discussions on topic. Off-topic discussions belong in the Mac Members Pub.
For Sale/Wanted Notices: Classified ads belong in the Classified Ads section of the website not on the Discussion Board.
Avatars should be kept clean and inclusive of all people. No porn, racist images, or otherwise offensive images.
Please remember that these forums are inclusive of ALL people, and we strive to maintain accessibility to everyone.
The "Mac Members Pub" is a more lightly-moderated section of the forum for discussions of things not related to MacGregor/Venture sailboats or sailing in general. This forum is not archived for long-term storage and old threads will be automatically deleted. Off-topic posts in the other forums may be moved here. While more lightly-moderated, posts in this forum are still subject to the restrictions above at the Moderators' discretion. Classified ads and other spam are not allowed in the Mac Members Pub.
Anybody who can live within these rules is welcome to participate on the Discussion Board. Members who abuse the rules will be warned by the administrators or moderators. Repeat or flagrant offenders may be banned from the board. If you cannot live within the rules please go someplace else.
Keep an open mind: Sometimes you will be faced with a thread you might not agree with it's imperative you keep an open mind towards all inclusive people and a neutral focus when replying. It is our duty to steer the conversations back into a positive nature.
Images: Please limit the number of images that you include in a post to three. If you want to show more images, please post a link to your online photo album directly. Otherwise, pages are just too slow to load for people without high-speed connections. Please use the Mac Mods system for posting mods. If you need more pictures for a particular mod, please met me know and I can increase the limit from the default. Don't just post Part 1, Part 2, etc.
Moderator Expectations and Guidelines
Respect the Discussion Board Members and Guests. The Discussion Board Members make up this community. If you feel you need to edit posts for content, please do so with a light touch. If discussion board members have an issue with the moderation, please ask them to contact the Moderator or Administrator directly. Posts to the Discussion Board questioning or complaining about Moderator or Administrator activity should be deleted.
Avatars should be kept clean and inclusive of all people. No porn, racist images, or otherwise offensive images. If the user has one of these PM them and ask them to remove the avatar. If the user does not voluntarily remove their avatar, please contact the Administrator.
Adult Content/Violence/Illegal Activity: Messages containing offensive / sexually oriented / violent / illegal dialog, images, content, or links to such will be deleted. Messages with links to or suggesting illegal activity will also be deleted. These actions could result in a ban.
Thread Steering: It will become nessessary to steer threads away from becoming damaging towards the poster and other users. Our policy is that we do not allow threads to veer too far off topic, even in community chat, to areas where it would be very easy to get ugly fast. Please do your best to keep posters from getting too personal during heated debates.
For Sale/Wanted Notices: Classified ads belong in the Classified Ads section of the website not on the Discussion Board. Spam posts of this nature should be deleted or moved to the Jailed Posts forum for evaluation by other moderators or the Administrator. If you delete a post regarding an item wanted or an item for sale, contact the member who made the post to inform them that it was deleted and that they are welcome to post in the Classified Ads.
Dealing with spam and potential "jailed" posts: If its "spam" IE. Lower Mortgage Rates, the famous PayPal scams or other known spam items you can just delete them. If its a user trying to advertise something move the post to the jail, PM the user and let them know we have removed their post and it is being reviewed and we do not tolerate spam. We can then make a decision based on what the post is relating to. The post may be edited for content and moved back to the forum or other actions may be taken as appropriate.
Moderators should own a MacGregor or Venture sailboat. The specific model of MacGregor or Venture sailboat owned by the Moderator is not relevant. Within the ranks of Moderators, no attempt is made to maintain quotas of owners of specific models.
Moderators may not use their ability to edit or remove posts containing content with which they disagree but which otherwise does not violate any of the above rules.
Moderators who are unsure of whether a thread or post needs to be edited, deleted or moved should post to the Moderators Only board to get advice from the other Moderators. Posts containing questionable or offensive content may be moved to the Jailed Posts forum for review by other Moderators or by the Administrator.
Moderators who abuse their position on the board may have Moderator status removed at any time and may be banned from the board.
Moderators who have no desire to help us enforce these rules should contact the Administrator to have their moderator status removed.
Forum-Specific Rules
DONT use the country-specific groups for general topic posts about:
Macgregor Powersailer discussion,
Performance and tuning,
Trailers and towing, or
Modifications.
DO use country-specific groups for topics related to:
Country-specific events,
Finding spare parts or repair facilities in your area,
Country-specific sailing and towing rules and regulations,
Local sailing information (eg, boat ramps, access roads, facilities, hazards) and
Other stuff of local interest only.
