I'v been running two 70ah deep cycle batteries in parallel for everything, including starting. I knew that deep cycle batteries were not designed to handle starting, but since my boat came with it set up this way and it seemed to work, I left it that way, and all up I think those batteries were in there for maybe 3 years like that so when I replaced them about a year and a half back, I decided to save the extra expense of a VSR and separate starter battery and do it the same, Well these batteries now appear to be stuffed after about a year and a half so I figure the time has come to do it right.... Will go House and Starter and get one of these gizmos
http://www.ebay.com.au/itm/121321158259 ... EBIDX%3AIT
One concern of mine is weight, as it is very hard to keep the boat below the legal road trailering weight here and insurance means nothing if in an accident with an overweight boat.. So really, I want to keep the weight down as much as possible. Secondly, I want to try and keep all batteries in the battery compartment. The boats not here to take measurements of that, but I'm leaning towards something like this for house duties
http://www.australiandirect.com.au/buy/ ... ry/KA12150
My power use consists of a 47L fridge/freezer (couple of amps) which I normally turn to economy mode after the sun goes down (and 120 watt panel not charging) and then turn it off at bed time, also we have a 16 inch LED TV, which often gets a couple hours running at night, a stereo, chartplotter, electric pump, LED lighting, and that's about it, so not huge power demands. Still the more a/h the merrier and this would be nice if it fit in the compartment
http://www.australiandirect.com.au/buy/ ... ry/KA12230
but the weight is really getting up with this and a starter battery....
To cut a long story short, the questions:
What sort of start battery should I be using with the 50hp ETEC - Can I get away with just a motorcycle battery? I really want to keep size and weight down if possible and try and fit it all in the battery compartment?
Can some of you give me an idea of some of your setups, as in, house capacity and how it works out for you, and where you are putting your batteries in the M. Do they all fit in the battery compartment and if not, where are you putting them?
