How many ID numbers on Macgregor25 (1984)?.
CaptainSam
Post by CaptainSam »
Hello,
Does any body knows how I can Identify boat, Macgregor25 (1984) if its HIN on transom was erraised , as well as all tatoos and license regestation nambers. Is there any ather specific place to look for, like keel, boom, mast?
sailboatmike
Re: How many ID numbers on Macgregor25 (1984)?.
Post by sailboatmike »
My X also has a tag riveted on inside the cabin on the port side on the seat top, just above the battery box
Freedom77
Post by Freedom77 »
Hi Captain Sam: Are you looking at buying this boat. If you haven't I would be suspicious. Don't understand why anyone would obliterate hull ID #'s?? Don't know of anyplace else on the boat where #s exist. Not familiar with '84.This one could be HOT. Would be very hard to register. Where is Title? Just sayin'. Fair Winds and Full Sails...Old salt
I don't think 1984 had the transom tag. I believe the HIN was written permanently onto one of the stringers below deck, maybe by holes punched into the FG?
Altering it, removing it, covering it...these are all bad things to do.
Freedom77
Post by Freedom77 »
Freedom is 1976 V-25 and has transom tag with ID stamped on. This is required by law for the very reasons I have stated. It would be like removing VIN #'s from a car. Just sayin'. Fair Winds and Full Sails..Old Salt.
MacStonge
Sailboat: MacGregor 25
Post by MacStonge »
Hi CaptainSam, My '84 only has it on the starboard side of the transom around where the ladder is mounted. It looks like 2 lines of Dymo-tape embedded in the gelcoat.
Good Luck
Deliberately removed numbers screams 'run away!' :evil:
CaptainSam
Thanks Guys,
That was my boat stolen from me a few years ago. Now it's coming back home.
:o Say what?
If that's the case, and if you haven't found the potential other location for the S/N, I'd call BWY and ask them if they know where it might be. If there is one, somebody has to know where to look.
And I hope it all works out for you. And the thief spends an eternity in irons, with flogging sails and an overflowing porta-pottie. :P
Freedom77
Post by Freedom77 »
Capn Sam: Did you have any luck with ID #s?
