Yesterday having been a thoroughly disappointing day for sailing here in Virginia, previously promising Accuweather forecast notwithstanding, instead I finally got around to mounting that roller. First of all, I should point out that the actual roller is far prettier than its picture on the BWY website. The instructions were clear and its assembly straightforward. Noone, no matter how tool-use-challenged, need fear this particular mod, that's for sure. I did have to head off to the hardware aisle's Stainless Doodads section for a slightly thicker 5/16" stainless bolt than the ones supplied in the kit, so as to be able use a preexisting hole, but your mileage may vary. All in all though, the whole process took less than an hour, which included a number of trips up and down the ladder to find a better radio station, finish a Wawa French Toast and Sausage Breakfast Sandwich and stare at the hazy sun trying to peek through for a while now and then. (Pro Tip: you can use a drill bit laid lengthwise instead of a "round file" described in the instructions to make a perfect groove for the bowlight wiring to run through under the roller assembly. And if your wiring's a little short, just angle that groove a bit forward instead of directly to port, as described in the directions). Here's how it looks on the bow (also showing our little blonde "Matrioshka" figurehead, who only coincidentally bears any resemblance whatsoever to the Admiral, and does not at all constitute a shameless gesture of cultural or gender pandering on my part...No, not at all..Wouldn't hear of it!):
One thing that occurred to me during the process was how handy my cheapo Harbor Freight 105 Pc Tool Kit with 4-Drawer Chest has proven itself to be aboard. Sure, most days you can get by with a couple of screwdrivers and a few wrenches and pliers in a big plastic Folgers coffee can, but every now and then it's good to have the right tool for the job handy, all neatly laid out with a place for everything and everything in its place. Yesterday it was awfully handy to have a perfectly-fitting Phillips-type screwdriver head that I could fit into a ratchet with an extension bar to clear the roller-furling drum, and there they were. The kit itself fits just perfectly into that storage area forward of the galley...almost like that opening was tailored for it. Just drop it in and slide it a bit forward, and it'll rest nicely on that reinforcing member that runs the length of the bilge, keeping it well above any water that may gather there. Sure, its tools are not the epitome of the toolmaker's craft, but then again they are way better than you might frankly have any right to expect for the price. These little kits are frequently on sale for 30-something bucks, and/or you can just use one of those 20% or 25% off coupons. You could maybe get a Snap-On or Craftsman ratchet extension bar for that kinda cash...a small one. They're "handy" little sets is all I'm sayin':
