Know Your Rig Types (XKCD)
DaveC426913
Post by DaveC426913 »
"I wanted to make the world's fastest yawl, so I made the aft sail bigger, but apparently that means it's not a yawl anymore! It's a real ketch-22."
https://xkcd.com/3193/
Re: Know Your Rig Types (XKCD)
As long as you don't have a "keel rig". :D :) :( :o :? 8)
JotaErre
Post by JotaErre »
¿What's your opinion about this one?
pitchpolehobie
Post by pitchpolehobie »
Don't show roger mcgregor that picture.He might try to make some
2002 MacGregor 26X: Remedium
Tohatsu 25HP
Be Free
Post by Be Free »
JotaErre wrote: Fri Jan 23, 2026 4:03 pm ¿What's your opinion about this one?
It looks like it would do quite well running but I have doubts about it's ability to sail close hauled. :D
Hamin' X
Post by Hamin' X »
On the serious side; the difference between a ketch & yawl is the location of the mizzen mast. Ketch is in front of the rudder post (you are trying to ketch it) and yawl is behind (south end of the boat, yawl). :)
~Rich---Hamin' X---N7ZH~
JotaErre
Post by JotaErre »
Hamin' X wrote: Sun Jan 25, 2026 6:45 am On the serious side; the difference between a ketch & yawl is the location of the mizzen mast. Ketch is in front of the rudder post (you are trying to ketch it) and yawl is behind (south end of the boat, yawl). :)
Also, the mizzen mast is taller and the sail larger in the ketch than in the yawl.
Hamin' X
Post by Hamin' X »
JotaErre wrote: Also, the mizzen mast is taller and the sail larger in the ketch than in the yawl.
Yes the sail on the yawl missen has a larger moment arm, so it must be smaller. :)
DaveC426913
I just remember that 'k' comes before and 'y' comes after.
Educate me, please.
Before what; after what??
Never mind, I just looked it up. Before and after the rudder post.
I ketch myself before I make a fool of myself in front of yawl.
JamesToBoot
Post by JamesToBoot »
DaveC426913 wrote: Tue Jan 13, 2026 1:27 pm Image
:D :D :D :D epic
-james
Novice Sailor
'91 26S, fixer-upper, 55lb w 280ah lithium, need stern rail
Cruising Grounds: Lake Murray, youtube
So what do you call a boat that has two mast of equal height with virtually equal sail areas but are not gaff rigged?
Be Free wrote: Sat Jan 24, 2026 12:37 pm
Idunno… if a sail is a wing then there might be the possibility to sail close hauled… :wink:
Although holding on to the mast (Handle? Shaft?) might prove problematic… :D :D
Gotta give them at least style and creativity points!
Who knows, they might be on to something!
Thanks JottaErre!
Looks like fun! :wink: 8) 8)
With a strong enough wind, you become Mary Poppins.
Be Free
Post by Be Free »
I think in that much wind you would have to be heeling quite a bit.
