trailor bumpy on truck tonque.
While towing my empy trailor (26x) it viberates hard up and down on the towing hitch. Tryed tightening the bolts on the trailor brake slide, but the trailor tongue still rattles hard up and down on the trailor ball. Hard to explain. Has anyone else had that problem, what can you do to stop it?
Rich Plumb
- Sailboat: Venture 25
It's normal for the trailer to bump and bounce around a lot when being towed with out the boat. I don't have a good solution for you. If you plan to tow it, empty, for a long distance, you might try reducing the air pressure in the trailer tires, say from 55 psi to 15 or 20 psi. Just remember to refill them again before you load the boat.
~~~~~~~~~~_/)~~~~~~~~~~
Rich Plumb, "Plumb Crazy"
26X, Covington WA
26X, Covington WA
- Night Sailor
- Duane Dunn, Allegro
I also found that the brakes were causing a lot of hop when the trailer is towed empty. I drilled a hole for a lockout pin in the hitch slide. Putting this in when the trailer is empty has greatly reduced the bouncing.
Even so, all this normal bouncing is back at the wheels. There should be no slop in the connection at the hitch.
- beene
Great idea, thanks Duane.Duane Dunn, Allegro wrote:I drilled a hole for a lockout pin in the hitch slide. Putting this in when the trailer is empty has greatly reduced the bouncing.
My trailer came with a brake by-pass pin, I will use it next time I pull an empty trailer, not like you need extra brakes when she's empty.
trailor ball
Was told to put on a 2 inch ball when I bought the boat. Hope its correct. As far as the towing pin is concerned thats good info Duane, I will try that thanks!
- kmclemore
Re: trailor ball
Yeah, 2" should be right... but if there's a 1 7/8" on there you'll get exactly the rattling you noticed... might want to check it? They are marked on he top.daver360 wrote:Was told to put on a 2 inch ball when I bought the boat. Hope its correct. As far as the towing pin is concerned thats good info Duane, I will try that thanks!
- Sloop John B
- Chip Hindes
The problem is with no weight to compress the springs and 50psi tires, both ride like rocks, as if there is no suspension at all. With this setup, it's difficult to keep the trailer wheels on the pavement whether braking or not.As far as the towing pin is concerned thats good info Duane, I will try that thanks!
The beauty of a surge brake-equipped trailer is that braking is directly proportional to the weight of the trailer. Everything else being equal, there should be no need to lock out the brakes when the trailer is empty because there should be very little trailer braking going on. I think you might be disappointed at how little improvement you'll see by locking the brakes out.
Of course, they're not nearly equal, but before locking out the trailer brakes, try dropping the tire pressure considerably. Like Rich suggests, the numbers say you should be able to run as little as 15psi in the trailer tires without damage, even less if you've upgraded the tires as many have. I think you'll also be surprised at how much things improve. If not enough, and if you have a good sized tow vehicle, only then should you lock out the trailer brakes. If you're towing with a marginal vehicle such as the legendary Ford Taurus or one of the smaller front wheel drive minivans, I suggest you try live with the bouncing, but keep the trailer brakes functional. 800 lbs empty weight is not much on a 3500 lb capacity trailer, but it's quite a lot at the end of a trailer hitch trying to push your tail out.
In general, I'm against locking out the trailer brakes for any reason and have never retrofitted my trailer with this capability. As someone who a number of times has forgotten to hook up the trailer lights, and once actually forgot to lock down the hitch on the ball, I know it would be only a matter of time before I forgot to remove the lockout pin; Murphy's says that would be just before I had to make a panic stop.
LOUIS B HOLUB
I have a moderate noise rattle level when towing my empty Mac X trailer, and in our case its caused by the receiver hitch and trailer surge brake coupler. Both items rattle with no weight on the trailer.
I had a loose 2" trailer ball on one occasion when towing the loaded trailer which was a "close call" (I hope your trailer ball isnt loose).
- kmclemore
I've seen them come loose before and I learned my lesson. Henceforth whenever I install a ball I tighten it down to the proper torque and then drill a 3/16" hole in the threaded bit that extends past the nut, as close to the nut's face as I can. Then I install a split pin (cotter pin) and peen it over. This will absolutely prevent any backing off of that nut.LOUIS B HOLUB wrote:I had a loose 2" trailer ball on one occasion when towing the loaded trailer which was a "close call" (I hope your trailer ball isnt loose).
