Cleaning rust stains from gelcoat?
PatrickS
Post by PatrickS »
I got some metal filings on my deck (thought I had cleaned up
completely but missed some) which have left little rust speckles
on the gelcoat.
What is the best way to clean those off?
tangentair
Post by tangentair »
I use softscrub with bleach for just about everything, not sure if it is good or bad but worked for me up to this point. You could try some chemical like Lime Away or one advertised to remove rust stains from sinks and bath tubs, in general I believe the gel coat is pretty tough, I would just be careful of solvents
Divecoz
Post by Divecoz »
Lemon juice and baking soda also those new kitchen erasers by the Bald guy...Mr. Clean .
Zoran
Post by Zoran »
FSR (Fiberglass Stain Remover) blue gel, you can buy it in any marine store, works miracles
Zoran
mike uk
Post by mike uk »
Oxalic acid is the magic ingredient - any product with that in it should just blow rust stains away. If you use it with the boat on the trailer, make sure you hose off the trailer well.
Mike
jasper
Post by jasper »
There is a product sold here called CLR (Calcium, lime and rust) which is effective on rust when I have used it on bathroom rust stains.
I am not sure what the active ingredients are.
Ron
Post by Ron »
My wife has Bar Keeper's powder soap that has Oxalic acid, which I have used successfully to remove rust stains.
Moe
Post by Moe »
Ron wrote:My wife has Bar Keeper's powder soap that has Oxalic acid, which I have used successfully to remove rust stains.
That's what we use and it works great on rust stains. Available in most grocery stores.
Moe
tangentair
Here is an interesting link to cleaning alternatives that was part of the full time saltwater slip thread
