Paul
Neither Roger, not the Mac factory has anything to do with furler installation, on either the X or the M. Furlers are installed by the dealer.Jeff wrote:So what does this mean, Roger is getting too cheap to put a furling fairlead on the bow like on the X?
Thats what I got a kick out it! Total waste of a cleat! Since it is a factory picture makes it even more amusing, to me at least.Chip Hindes wrote:Neither Roger, not the Mac factory has anything to do with furler installation, on either the X or the M. Furlers are installed by the dealer.Jeff wrote:So what does this mean, Roger is getting too cheap to put a furling fairlead on the bow like on the X?
IMO, the pictured setup is a total waste of what is otherwise a useful cleat, and it looks as if the line is not being led at the proper angle. Tell the dealer to install a bullseye fairlead on the deck, or do it youself.
As far as not drillng any holes in the deck, about half the dealer and self installed options on my boat have required drilling holes somewhere in the deck or topsides; a mental count (the boat is not near) puts the total number somewhere around 100 holes. Get over it and get used to it.
That is the way mine was set up. I found the line was rubbing on the hub can (whatever it is called). This is why I put it on the deck. Made a world of difference on our boat.RRice wrote:I used the Stanchion Mounted Bullseye Fairleads from Wmarine. I have one on each stanchion on the outside of the boat at the bow. I also run my line through the attatchment point for the mast raising stabilizer.
