Anybody got some suggestions please?
Paul
Yes, me too...normally only when raising the main. I have thought about trying to figure out a way to cover those bolt ends...but have never followed up on those thoughts.hartflat wrote:
Caveat... Although having nothing to do with the above setup, there's a very annoying snag that occasionally occurs when I'm raising, or lowering the mainsail. Every now & then, the mainsail halyard tends to get caught up on the portside bolts that hold the headsail &/or mast raising hounds to the mast. Every so often, I'm forced to climb on deck & pull the dang halyard loose... its a real PIA!![]()
If running the main halyard through a Harken 140 swivel block and THEN through some other block and THEN back to a cleat or clutch near the cockpit is working acceptably, by all means continue to use that system.
To me, the advantage of the Harken 140 is that the built-in cleat keeps the halyard tension consistent regardless of the position of the swiveling mast - and keeps that tension isolated to the mast itself. After the halyard exits that cleat on the base of the mast, it is slack. It can be released from the cockpit with an upward snap, although I must confess that I typically release it by hand at the mast, since I'm going forward to gather and tie the mainsail after it has come down.
You have an X, your mast doesnt turn...The only way to have the halyard work from the cockpit, and still have the use of the swivel mast is to cleat the halyard at the mast, using the 140's cam cleat, then there is free motion of the mast. That would be for the "M" .I run my halyards thru the 140 directly to the winches--no turning blocks. As parrothead sez, you have the option of access from the cockpit OR standing at the mast. JIb halyard, same way.
Yes, that happened to me too many times to ignore, the main halyard always gets hung up on the hound nut so when I installed a second spinnaker hound 18" higher I took out the hound bolt and put it back though facing the port side for both hounds thus just leaving a small bolt head exposed for the main halyard, so now it never catches anymore. As for the jib halyard it dos not catch on either bolt because it is lower and also on a furler so no more snags.hartflat wrote:Come to think of it Jim, the snag does seem to happen only when raising the mainsail... I covered the offending nuts with aluminum flashing tape & although that helped somewhat, I still have an occasional snag.Ray
I would agree, although I've never used a feeder.Oh, did I forget to mention that sail slugs are a must?
Another option would be to keep the bolt oriented the way it is, but use an eyenut, and lead the halyard right through it. No extra holes in the mast, either. Not cheap, though, and you'd have to use a jamb nut on the inside to hold the bolt orientation.parrothead wrote:As for the halyard snagging on hound bolts, etc. - simply install a couple of stainless eye straps on the starboard side of the mast and lead the halyard through them on its way down to whatever type of turning block you favor. Two straps should do it.Oh, did I forget to mention that sail slugs are a must?
