Putting numbers and sticker on dinghy
ris
Post by ris »
Some one let me know how you put numbers and the state sticker on a blow up dinghy? Mine only lasted 3 inflations before they fell off. All ideas would be appreciated. Thanks
jrcanoe
Sailboat: MacGregor 19
Re: Putting numbers and sticker on dinghy
Post by jrcanoe »
While technically not legal here in PA I use # boards that I zip tie to the gunnels of my cedar strip canoe. Never had a problem with fish & boat They have only remarked how beautiful my canoe is and how they wouldn't put stickers on it either.
Do you have to register a canoe?
I don't know about stickers on a rubber boat. Maybe cut out vinyl numbers and glue them on with some kind of adhesive for rubber.
yukonbob
Post by yukonbob »
My first choice would be stencils and some paint.
Norca
Post by Norca »
The admiral did ours with a permanent marker, using stencils,
The boat see little use, but still not too bad after 2 years.
It will be easy to re-do when it starts to fade.
jrcanoe
Post by jrcanoe »
RussMT wrote:Do you have to register a canoe?
Yes if you want to use PA fish & boat access ramps , State parks or run an electric or gas motor. The Law states that boats should be registered for the place of waters of principal use but how do I prove my canoe has more Canadian river miles than anywhere else!
jrcanoe
Post by jrcanoe »
http://www.boatingmag.com/how-to/instal ... table-boat
You could buy above but I just used a piece of plastic molding that goes on the bottom of walls.
Chinook
Post by Chinook »
West Marine carries a dinghy numbering kit which works reasonably well. You mail in your registration numbers and receive back a pair of flexiblle panels with the numbers printed on them, along with a place for the registration stickeer.
WM sells a special adhesive, designed for attaching the panels to inflatables. It's important to meticulously follow instructions, but the setup works fairly well and it looks good.
Obelix
Post by Obelix »
The best solution I found and applied was to get templates and paint the numbers on the dinghy.
WM is selling special paint and templates for this purpose.
Obelix
Obelix wrote:The best solution I found and applied was to get templates and paint the numbers on the dinghy.
Obelix
That is what I did. The paint which is used is flexible, and has stayed on my Hypalon inflatable for years. Keeping registration stickers on has been a problem.
P.S. I see ris is in Frostproof, FL. Where I was this weekend (New Hartford, NY), it was as low as -18F with a wind chill of -35F.
shrektruck
Post by shrektruck »
You've got to put the stickers on a stainless plate and then screw the plate to the inflatable part...make sure you use stainless screws too.
:evil: :evil: :evil:
