Well, you did install a BIG sink also.
What are you planning on using for water storage?
Yep. The sink was both too deep and too long (front to back) for a comfortable faucet install. If I have any trouble/leaks, I'll put an access panel in the back so I can have an easier go of it.
Those look nice, and extremely convenient for carrying/loading. Where did you plan on storing them aboard?Inquisitor wrote: ↑Wed Oct 14, 2020 7:55 am I was looking at these for my mod.
https://www.amazon.com/API-Kirk-Contain ... 06&sr=8-25
In my planned mod, these will fit almost perfectly. I'd make slots for all four, but can take/leave them at home depending on the adventure. Handles make them easier to go forage for water when necessary.
I like it! Can't wait to see pics!Inquisitor wrote: ↑Wed Oct 14, 2020 2:26 pm Hmm... I haven't published like your great thread. Things are still tentative and the forum gets a little negative when you make changes that can't be unmade. I don't ever plan to sell, so I don't care. To me, the Mac is my personal play toy.![]()
In a nut-shell, I'm moving the head. This is in construction and I'll be using an AirHead composting toilet that won't fit in the current head location.
I will also be extending the front birth into the head location back to the daggerboard trunk front wall. The Admiral and I don't really like sleeping in the aft birth... especially in the summer. We have one of the rip-stock cloth funnels for the fore-hatch and it makes a very nice breeze over the front birth when on the hook.
The tentative part is where to put the water. I need to get the boat into the water first and see some things about weight and balance. I'm getting the engine worked on and you've noted my cleaning binge. You've also noted on my other thread, I drive it with lots of sail up front. It tends to plow like a FWD car. I may need to put the water under the aft birth. In that case, I obviously won't be using these tanks. However, if I can put them up front, I'll put them in the floor centered on the daggerboard. There is ~16" clearance and I can just get plumbing on top of these tanks and under the mattress.
Keep the hits coming.
Great idea! I should have brought this up earlier...Inquisitor wrote: ↑Fri Oct 23, 2020 1:25 pm I painted my bilge. Solves that glass shards problem AND lightens it up. Before I was thinking about adding LEDs to the bilge, now I can see things down there far better.
Nope. Not sure. Just thinking that with grandkids and non-sailors, the water usage may be a bit less at the lower pressure, in addition to minimizing leak potential.Inquisitor wrote: ↑Wed Oct 28, 2020 4:06 am You sure you want a lower pressure pump? You can use this one to pressure wash the dishes and deck both.![]()
