How long does the engine have to sit unused to warrant winterization?
FWIW, I have a Honda 50.
I presume that freezing isn't a big issue, since in the down position,
essentially all water drains out, right? And fuel and oil won't freeze
(at North Texas temperatures at least).
The "winter" is pretty short here, and I don't expect the boat to sit
for more than a month or so, which it occasionally has done during
the summertime anyway. I'm actually planning a weekend sail in
mid February (after 19 years in Finland, anything above 50F is
acceptable, even if not optimal, sailing weather to me, especially
if the sun is shining
If I pull out the old trash can, fill it with water, and run the engine
occassionally (in between the really cold days when freezing is a
possibility) to keep the fuel from sitting in the carbs too long (and
I use stabilizer in any case) is any winterizing really necessary?
Is there something I'm perhaps missing?
Patrick
